PC V has arrived
PC V has arrived
Beitragvon Nigel » 08.04.2010, 19:08
Hi friends,
My Power Commander V arrived at my dealer today. I will get it fitted next week with the Autotune facilty. Will be good I hope.
Nigel.
Nigel
Re: PC V has arrived
Beitragvon MSHPU » 08.04.2010, 19:55
Are you using it to tune the ECU mapping to an aftermarket slip-on? I don't think that will be necessary with the slip on and if you have the factory shift assistant installed there isn't even a need for the Quick Shifter module. At least from what I can tell, what are the features you gain? BTW: you should be glad you can use a Power Commander, they are not street legal in Germany because they affect emissions... :)
Beitragvon Nigel » 08.04.2010, 20:06
MSHPU hat geschrieben:Are you using it to tune the ECU mapping to an aftermarket slip-on? I don't think that will be necessary with the slip on and if you have the factory shift assistant installed there isn't even a need for the Quick Shifter module. At least from what I can tell, what are the features you gain? BTW: you should be glad you can use a Power Commander, they are not street legal in Germany because they affect emissions... :)
I have a full Evolution Akrapovic. It is very very lean up to 8000rpm and then too rich after that. Especially at small throttle openings it is up to 19:1 air fuel!!! It needs a PC urgently :) I am just using the tuning function with autotune (I have dtc and shifter).
Nigel.
Nigel
Beitragvon shicky » 08.04.2010, 22:18
coole sache nigel
dann berichte mal auch gleich wie sich der einbau gestaltet
und wie der so funzt
evt noch was er bringt beim drehmoment
prüfstand wäre auch super
02.06 salzburgring
12-13.07 slovakiaring
06-07.09 lausitzring
shicky
Beitragvon Nigel » 08.04.2010, 23:05
shicky hat geschrieben:coole sache nigel
For sure. Fitment next week then Autotune over the weekend and dyno after that. I will post the charts as soon as they are done.
N.
Nigel
Beitragvon shicky » 08.04.2010, 23:38
also bis nächste woche :lol:
02.06 salzburgring
shicky
Beitragvon audacium » 09.04.2010, 08:52
@Nigel:
I understood that there might be problems in using a Powercommander with Autotune together with DTC and ABS, that is, it might disturb the correct functioning of the latter. At least that's what Otto Leirer from Team Reitwagen said in an interview. It was also mentioned in a thread here: http://www.s1000rr.de/forum/viewtopic.php?f=4&t=581&start=15.
I am also curious to see you results :)!
audacium
Beitragvon Nigel » 09.04.2010, 10:09
I have been assured by DJ that there are no issues with the DTC and ABS.
Nigel.
Nigel
Beitragvon audacium » 09.04.2010, 15:39
Sorry, who is DJ ;)?
Looking forward to hear from your results.
audacium
Beitragvon Nigel » 09.04.2010, 17:38
audacium hat geschrieben:Sorry, who is DJ ;)?
Dynojet.
N.
Nigel
Beitragvon Nigel » 12.04.2010, 15:02
Sorry guys. I got a call this morning to say that the part is on the invoice with a note that it is on backorder :( It is still not here!!
Another 2 weeks he says!
Nigel.
Nigel
Mitglieder in diesem Forum: 0 Mitglieder und 44 Gäste
